The next option is a carbon steel insert with 2mm wall thickness, if the tapped hole is good, it will be strong once done:thumbup:
Would that be a Time-sert insert? I use Filtec coil system which has stepped tap for openining the holes but only use it as I don't get enough plug repairs to justify the cost of Time-sert.
slim
Amazon - it is the only stuff I have found to truly resist petrol!
thanks very much spud - so just to belt and braces it - the 'correct' size seal is leaking air - not on the crankshaft, around the outside. To remove it I'd waste the seal so should i just squeeze it down around the outer seal. I've got an old pioneer that i don't think i can get a seal for that's leaking in the same place - would a squirt of this be a reasonable repair in those circumstances?
cheers and much appreciated as usual
slim
No not Time Sert - they use screw taps that are specific to their inserts - PITA in my opinion!
The cheap stepped taps are pretty poor and brutal IMO - I will be using a HSS hand reamer for a much more accurate finish for the tap - the better the tapped hole, the stronger the bond.
I also will use a decent high temp thread lock - it has worked damn well on a MS460 before:thumbup:
Have you ever used Heldite?
I'll try this Sealall, how hard does it set?
Semi hard - not like an epoxy - a bit like hot glue in hardness - goes off pretty quickly, fast solvents!
It my be that the seal is Imperial and not metric?? Usually seals will be a tight fit on both the ID and OD.
It is reasonable to force some of this down any cavity between the seal and the recess it fits in to - I am wondering if you have measured the crank recess and shaft diameter correctly.
Some seals may be non standard sizing!
If the seal has a steel case, then you can tweak it a little with pliers to increase the OD, then seal in place. I have used loctite bearing lock as that was to hand, it sets in an an-aerobic atmosphere to as long as the joint is close it works.
H-A
