What's on your bench today?
spudulike
Future project for it Steve!
Chris
Yup, thats Brad in the US, he does some pretty trick stuff to many saws, asked him for a bit of advice here and there - cheaper than forking up expensive cylinders!
I think Burrell would like to test out the 372 when done as he has just got a busted one for fixing!
id love a brad tunned 200t
A friend gave me a 2004 044 to look at as it would run fine and then stall, I took a look at the diaphragms and they were pretty stiff, (saw had been shelved fueled) I called up my local dealer to buy the new diaphragms and it turns out the saw has a USA spec Walboro carb on it, which is a little unusual but anyway, replaced the diaphragms and it was the same, just thought I would swap the NGK plug and it solved the problem immediately.
I always use Bosh plugs on my saws.
Do you find a difference in performance ? Never used anything but NGK
Yup and I have read the thread that accompanied that vid and it is what I have found - the exhaust port can be widened but by not that much, the inlet port can barely be widened - if anyone disagrees then feel free to do so and snag the rings:001_rolleyes:
The squish can be lowered by around 0.4 - 0.5mm and the muffler can be modded that can make a decent difference.
Peter is right, don't know if he is repeating what I have found but it is fact.
The only thing I haven't tried is messing with the ignition timing.
