You argue for 17 mostly as it's a close quarter calibre and fragments easily so ricochet is less of an issue.
Personally it's more the lack of size of the entry and your relying on fragmentation and placement.
Providing your not after match quality, you can pickup millsurp or cheap 223/556 for less than £1.50 each.
Countryman derby is £17 per 30 or £44 for 50
3 hours ago, Stubby said:
Ruger .22 250 Me thinks is the tool .
Barrel burner, I liked the .223 & .222 but if you need a do-it-all, 6mm in some form is a good calibre.
I think that is the minimum for live targets, it was a major factor for me.
In fact I much preferred rolling my own for paper and live shooting
Edited by BillQ
I shoot with a guy who swears by that  calibre Stubby, he’s out nearly every weekend and at least once during the week all year round . He’s had no trouble with excess or premature  barrel wear, mind you he does load his own. I tend not to take too much notice of the “barrel burner” stuff, possibly if you are banging out rapid fire strings at comps but for pest work etc 🤷‍♂️.
Fast and flat ! .
Different strokes for different folks.
.22 Hornet is as quiet as anything if moderated ,very cheap to reload for and bloody accurate. You cant really compare it to a 223,that would be like comparing a mini cooper to a Ford Mustang.
If you want somthing even more obscure,try a 218 Bee or 219 Donaldson wasp. I had a .218 in a Martini Cadet action,cool little gun.I had it chambered in .218 because it was originally .222 rimmed and it ran out of barrel threads after cutting the chamber off. If you reload ,then you may as well get something fun. Brass lasts for ever and everthing else is the same as .22 hornet.
1 hour ago, Stubby said:
Fast and flat ! .
Sure is but with good optics is it necessary? It will be less affected by a cross wind but not by that much but is using a lot more powder compared with a 223 or 222, both of which are good accurate rounds. I'm not sure if 22 250 is fussy regarding bullet weights and twist rate my old triple didn't like 55gn and above but was fine on fox, crows and roe out to 200- 300yds with the right bullet.
I think if you shoot for long enough you will get the exotic calibre bug. Been there done it right up to 338lap mag and spent plenty for the privilege. Nowadays I’m down to 22lr, 223 and 308 which suits me fine. Good ammo for pest work mil surp if it’s a day of making brass.
I also keep my shots on live targets to 150m-175m, the fieldcraft aspect of getting close is every bit as important if not more for me than calibre or optics.
Hell yeah! Close enough to whisper in their ear.
Edited by BillQ
