2 minutes ago, Mike Hill said:
Yup they are 1919s.
I can't tell for sure what's going on in the back where the spade grips/ solenoid/ air actuator should be.
A buggered shroud or barrel is a hallmark of a crash but those shrouds do look like water jackets and some were water cooled but obviously not on aircraft.
I will send the pictures to a guy who will know for sure. He is in another timezone so might be 12 hours or so
Round in the chamber without a primer strike is weird for an open bolt gun but who knows?
Is the open bolt an RAF only thing  or were all brownings in UK usage the same. I’ve seen a couple of water cooled twin aa set ups online.
I'd say it would have just been the aircraft guns.
The trigger bar on an open bolt gun would have been quite a bit shorter than a closed bolt gun because it releases the bolt into battery and not simply the striker.
It's been years since I have opened one up and then it was trying to get it to fire attached to an air compressor.The seals in the actuator were buggered and we filled it with O ring grease to get it to seal.
Sometimes I really miss New Zealand.
https://m.youtube.com/watch?v=VMljA1wm0FY&pp=ygUYT2VybGlrb24gZ3VuIG5ldyB6ZWFsYW5k
1 hour ago, roys said:
I’m impressed Mike
That's not me shooting BTW, there was a film of them shooting feral goats with an Oerlikon but it got taken down or disappeared.
Tonight I tried my new old  barrel on my Krag Jørgensen from 1897. Shoots really good .
100m ?
If it is that’s not a shabby group for irons
55 minutes ago, Johnsond said:
100m ?
Yes 100m
First time out with that Rifle and just some random old reloads
41 minutes ago, Joe Newton said:
What size target, Mike?
No entirely sure,I think the black bit is 8cm . 10mm between each ring?
The vital zone on that deer target is 30cm across.
