We are pulling a load of forestry trees at the minute, throwbag, bull rope sent up, choked on itself, then making a loop in the rope to attach the winch hook for the Tirfor.
Β
On heavy leaners the winch is obviously cranked pretty hard, and the knot in the rope (we were using a fig-8 on a bight) tends to get really hard to undo.
Β
Can anyone recommend a mid-line knot that won't tighten up when subjected to a large load?
Β
Thanks.
  • Replies 55
Β
Β
Β
QUOTE]
Β
As said bowline. Just double the rope and stick youir bowline in. There's an easy way in to open it and I've never known one come undone. (impossible mid pulling rope if tied correctly).
In the past i have introduced a lump of wood or smthg solid into a fig.8 or bowline on the bight - makes it much easier to loosen up. Hoow about splicing a large dia. heavy duty prussik loop, never tried but might work also..?
I find that the alpine butterfly can be a pain to undo, even when you use hand operated pulley systems.
Β
I agree.
Β
Get a stick and put it in the middle of the bowline and stop it binding up. :thumbup1:
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
