50 minutes ago, 5thelement said:
Needle bearing probably once a week/fortnight, takes two seconds with Husqvarna no point in not doing it.
Harder on Stihl. Had to (carefully) grip the splines on the clutch drum with water pump pliers and tap those to drift the drum off. Doing it often would unduly mar the splines. None of the manuals had any less destructive ideas.
Edited by AHPP
Someone take a picture for my curiosity please. Haven't been near a Husky in years.
6 hours ago, Stubby said:
Been saying that for years . Acts like a lapping paste .
Spot on. If you're going to grease, then do it weekly , to the point of squeezing out the excess dust and shit contaminated crap out, replacing with fresh clean grease. Wipe off grease nipples/torx bolts first to keep everything clean, and don't drag the nozzle of your grease gun through all the dust and gravel in your yard. Fail here and your just injecting grinding paste straight into the heart
One would also assume the needle cage bearing are made of glass fibre not just for strength but effectively a glass bearing surfaces against the stainless needles.
They do make glass bearings for that reason, no lube ever required, usually the cage fails before the glass beads.
Husqvarna needlecage bearings are still made from metal, Stihl only changed them around the time they updated to MS261/362 etc from the earlier models.
Guessing that's pre 2003 on Stihl ?, that's about the oldest I've used and kept running including changing clutch springs with screwdriver and needle nose pliers.
There is a hole in the end of the shaft that allows you to pump grease through to a hole which sits directly under the Husqvarna needle cage bearing, no need to remove anything to grease it.
There is a hole on the end of the shaft
On a Stihl, unfortunately it has no function, amazed that Stihl hasn’t adopted this design, especially with the amount of MS261 fails that I have seen coming in on training courses.
Shaft blind drilled to a cross drilled grease port. Got it. Yes. Good idea. Unless it doesn’t matter. But I’d probably grease a Husky if it’s as easy as that.
11 hours ago, doobin said:
I’m sure you know this, and you’re just being facetious with the resident drunken anarchist.  But for the benefit of those more easily led astray…
These don’t have a proper seal, just a loose bit of plastic against the end where the blades protrude from. It’s not like a round shaft where a rotary lipped seal can easily form a total seal against the oil.
I laughed at his post because although he have have filled it with chain oil, he hasn’t yet realised that there’s none left inside it unless he’s stored it standing up for the last 15 years and not used it.
Your workshop is full of trimmers for the reason that people assume once it’s ’filled with grease’ then it’s good. What actually happens is that they get hot with use, the grease gets liquid, and escapes from the blade end. And then it’s not replaced. What’s left inside emulsifies with the loss of the oil component of the grease through heat and ends up in the familiar waxy looking crap everywhere in the head except where it’s needed- on the gears and in particular the con rod bearings.
stick a grease nipple into the fitting and grease it every other time it’s used and they will not fail.
Funny story, I went out to a council yard who had purchased some Husqvarna 240r brush cutters, they were complaining of the clutch slipping and black gunge coming out of the clutch housing, I asked how often they pumped grease into the gearbox, oh every day they said with an air assisted greaser, they had actually forced grease right up the bloody tube and shaft to the point it was coming out of the top, priceless!
  • Haha 4
