First time stating the saw up since about 10 years ago. So dont remember much
But it runs well, apart from hard to start hot and there is no oil on the chain what so ever! Yes the oil tank is full.
Where do I start look please?
Thanks
PS 14" Husqvarna 135
Thanks
The obvious is to clean out the bar groove and oil inlet hole . Start the saw without bar and chain . See if any oil comes out of the out let . Careful how you rev the saw , don't want the clutch spinning off if its a thread on one .  The hard to start when hot could be low compression . The 135 is not a pro saw so maybe not worth spending too much money on it .
Edited by Stubby
Christ here we are again running the saw with no bar and chain, I strongly advise you do not do that, on the over run they can, and will spin off, once away from the drum you have two shoes one spring and a spider flying through the air at speed.
Yes  clean the bar delivery holes, next you need to remove the clutch and check the oil pump gear behind, then remove the oil pick up pipe and filter and clean, has this been running with bio oil?
I did err on the side of caution regarding that Andrew . 🙂
I thought someone said that couldn't happen....tell that to someone that has seen clutch drums disappear down their drive at great velocity.
Or bounce around inside a small workshop hitting every wall, ceiling and floor, at least twice,  before disintegrating to all the component parts,  some of which were never found again.....memorable!!
Yep, don't trust an exposed clutch
I had a great time one morning in Bournville figuring out an oilling issue on a 2511 Echo.
Bar was clear and wasn't pulling from the clutch side. Redneck field strip with the impact driver to remove the clutch, oil drive etc. Cleaned everything and reassembled. Started the saw to check oil with the sprocket cover off and the clutch made a runner like a black guy from the police.
My reaction was to try and catch the spinning clutch left a decent glaze on my right palm before I pulled my hand away and the clutch made good it's escape over the car park. Didn't bother trying to find it at that point. New clutch from @Mark_Skyland along with the washer that goes under the worm drive that caused the failure.
  • Haha 3
Mine was a Stihl strimmer. Put a new clutch on and fired it up without the drum.
BANG! AND THE CLUTCH IS GONE.
No windows or teeth broken. Just eight quid of shoes and springs that went somewhere. Cheap mechanical instruction.
not connected to chainsaws but relative to things revolving and going wrong, at Santa pod in the mid 70's I had the pleasure of having a sit down with Don "Big Daddy" Garlits who told me of the famous flywheel explosion that severed part of his leg, as a young petrolhead  trying to build cars faster and faster on a budget that wouldn't buy a decent set of tires for any car he had, I was running an aluminium bellhousing, his rather graphic tale convinced me to run a purpose built scatter shield, built by the late Alan "bootsie" Herridge and about ten or more years later I had a flywheel detonate around the 125mph mark during a "street race" the damage completely disintegrated the flywheel,clutch,pressure plate,and even the input shaft on the box, but that shield contained it all.
the moral of the story, never trust any spinning mechanism without the appropriate protective covers, you might get away with it more than once when it goes south, but that one time you don't might  be catastrophic, take a look at the photo of the Garlits explosion.    this was before you sat with the motor behind you, you literally straddled the transmission and prayed it held together. these days the structural integrity of these machines is off the scale compared to those early days.
