2 hours ago, 5thelement said:
The first thing HSE will need is a thorough explanation as to why a tracked mewp wasn’t being used to dismantle the tree instead of climbing, costs overriding safety will never be accepted in a courtroom.
That's the last kin thing I would want to use.
17 minutes ago, Joe Newton said:
You really don't like to be wrong, do you?
The decision was made to put a climber in the tree, are you saying that I am wrong to suggest a mewp would have been a safer option, if so, why?
Edited by 5thelement
28 minutes ago, peds said:
Does anyone?
Well it's pretty much vital if you ever want to learn...
I'd love to know how you reached that conclusion having not seen the video.
"Would a MEWP have been safer?" is a plutonic question. Can you be sure that the machine (base/outriggers & operatives/basket) will be completely clear of falling material/the main trunk when it goes?
It MIGHT be safer, but it's not the SAFEST means.
It's the first point of the WAHR.
12 minutes ago, Mark Bolam said:
Big MEWP with good outreach would have been safer than climbing, but still not the best option.
I know the first point of the WAHR, but we can obviously assume that that horse has well and truly bolted.
A decision was made to WAH, was there a safer method than climbing, probably several, but none of them were used.
MEWP would have been worse for anything other than setting ropes without disturbing anything. Unless it's one with a lot of sideways, you're putting the boom and carrier in danger of being hit. And even if it is one with a lot of sideways, the basket still risks being hit. So potentially you go down with the basket or get rattled to death in it when a crown comes past you like a train going off a cliff.
Climbing, at least you're tied to another tree and can swing out of the way. I'll often make a cut without being lanyarded in so I can swing out of the way or even be conkered out of the way. Better than being fixed there and smooshed in slow motion.
But, from what I can see from the video, the best way to do the Cheshire road tree was from the floor. Step cut it and roll/pull/walk the butt until it falls.
