I wouldn't bother with electric hedge trimmers unless you are doing a regular light trim job. I don't use a Kombi system either. I rather use dedicated tools for the job. I use the HL94 long reach with the angled head for all my hedge trimming work. Wearing ear defenders isn't an issue for me.
I don't do a vast amount of hedge cutting, but there's a number of hedges I cut only once a year with the top of the range husqvarna battery machines. The 70cm handheld, and the telescopic long reach. Poor old petrol trimmers sit in the shed gathering dust, no use for them now.
I dont mind ear defenders but the protos ones are not great.
I'd be happy with petrol if they were as quiet and easy starting as my Echo 2511!
Afaik most 2 stroke tool exhausts are a hollow chamber with a spark arrester screen. I wonder if adding some exhaust wadding would work and not screw up the mixture, or catch fire!
I have a load of tabs open to look at, of cordless hedgers but not had time recently!
In a word, no, bunging up the exhaust wouldn't be so good.
Might be able to do something with a larger chamber and a couple of baffles inside, perhaps double skinned... ask those who mod saws what they do to make them louder and do the opposite... but clear path for the exhaust and no back pressure that wadding would give (2nd or 3rd tip for a poorly performing saw is always check the screen is clean)
Since I retired from cutting ( anything other than my own fire wood ) I find the indecent  drone of a hedge cutter in the distance so depressing !
I've used a kombi Stihl hedgecutter for years now with the hedgecutter long reach attachment. I got it so I could change to the pole saw attachment when needed
Is the dedicated HL94 any better for hedges than the kombi? I never researched if it was lighter or anything. The sound from mine is completely deafening I don't know if that's unique to my machine or not..
Is it a 2 stroke or a 4 mix engine? The latter are a fair bit quieter with a less piercing tone. I find the 2 stroke much more reliable to start - the two 4mix KM90s I have can be pigs to get going once hot
The 4mix hard to start when hot problem is due to the valves needing adjustment- very simple to do.
I just checked it's a KM 131R. Which when I google says is a 4 mix engine? It has been absolutely abused which may factor into it
  • 3 weeks later...
On 27/10/2024 at 15:02, Dan Maynard said:
Folding, it spends some time straight but a fair bit of time not. I reckon the straight ones are only really good for large perfectly flat hedges, so maybe the ideal is one of each.
The folding part is a point of weakness to be honest, which I have seen online review say as well. I'm using my own so just try to be careful and so far been ok. I don't do a huge amount of hedge cutting either.
Have a few days off so some time to look at tools, I still need a decent cordless hedger.
Is that the DUN500WZ model?
Shows the max cut as 23mm, seems plenty?! Not sure what the Stihl petrol ones are.
