  On 06/10/2024 at 12:55, pembswoodrecycling said:
There’s very little wrong with it to be fair.
at the moment we run it off the tractor, so I want a PTO version to be able to use our smaller tractor which is waaay too slow on it’s own hydraulics.
we fabricated a big table for it and that was a massive improvement.
the biggest complaint I’ve got is the tiny axe head they have can only ever split one log at a time, and the fillets that strengthen the table makes getting big logs close enough to split quite difficult sometimes.
there’s also a stupid gap between the axe and the splitter body that is prone to getting bits wedged in.
I’d also like a more powerful ram without sacrificing speed, which means having a well designed hydraulic system.
Don’t get me wrong, I love the Oxdale and would have another one in a heartbeat, but a bigger wedge that goes right back and a stronger ram would make all the difference to me.
If money was no object I’d buy an Axis because I like their setup, although I don’t see the need to buy an expensive to buy and expensive to run petrol engine when I could use an 80hp tractor for no cost.
what I’m really looking for is a splitter as well thought out as the Axis, but tractor mounted with a PTO pump.
Expand
I sat my Oxdale on an Ifor flatbed trailer and ran it off extension pipes from the tractor hydraulics, it would have been better still if actually fastened to the trailer but wasn't enough of an issue to ever make that modification. Those pipes actually came from Hand as a result of me complaining about the splitter they sent, it went on for months of them promising a new splitter but ended with me saying just give me some new pipes.
I'm sure you already figured it out but a length of wood the right size held against the bit that gets stuck behind the blade and the bottom of the ram pushes the stuck bit out on the return stroke. A feature pretty much designed into the Eastonmade Axis.
  On 06/10/2024 at 19:28, Peasgood said:
Yep that's me but you can feck off with the old bit, I am only 60!.
As for running it backwards, yes I am sure you are right because it did have more power if piped different but the return never worked if it was that way around. I never got it to run how I thought it should but it worked well enough. It arrived to me very badly put together, it would not function at all because the guards over the levers stopped them from working, the pipes weren't in the right place along with various other things. Yes the height was wrong too, I sat it on a pallet when using it.
Expand
Haha, I'm only 42, so I'm just a whipper snapper 😉. Nice too have met another member albeit a few year back.
I stripped absolutely everything off it including the guard and upped the hoses 1/2" feed and 3/4" return hopefully it breaths easier.
Carroll engineering make a good range of splitters, they have some UK distribution as far as I know. They're a small outfit and will build to spec. Very popular over here.
There's also proarc, but they're no longer being made, great splitters if you can find one, but I don't recall seeing a pto model.
Expand
I looked at Carroll, they do look well built. UK sales through Field and Forest apparently
http://www.fieldandforestltd.co.uk/
Things have moved on… I’m very taken with the Ryetec CV16 and is not massively out of budget at £4700.
But I’ve been thrown a curve ball, there’s a Balfour pro22 for sale locally. I’ve always fancied one of these, are they any good for short logs or only any good for billets?
  • 2 months later...
  On 06/10/2024 at 16:49, scbk said:
Not seen it in real life but always liked the idea with this one, a slow ram and a fast ram, and a log lift
HARBROOKENGINEERING.CO.UK
Heavy Duty Hydraulic Log Splitter made in the UK. 10 & 20 ton twin ram design gives you the best of both worlds - speed & power.
Expand
These guys use one of these, it looks like an excellent bit of tackle -
WWW.INSTAGRAM.COM
152 likes, 0 comments - goldi.logs on July 25, 2024: "Light work splitting logs with the ultra double axe 🪓 🪵 #firewood #logsplitter #logs #lumberjill #logprocessor #kindling".
We've got a PTO splitter from Sullivans Engineering, very pleased with it, great table height, and really well built. The little David Brown and the splitter have been such a good combo, pretty agile and very economical to run, and I drag Dave out to site quite regularly.
We're on a 16t model, you'd probably get a bit of a quicker cycle time with 13t ram. The only thing it really misses out on is not having an auto return on the head.
WWW.INSTAGRAM.COM
84 likes, 5 comments - woodlouseindustries on December 6, 2023: "What's that? You didn't want to see a grumpy mince pie fuelled woodbloke splitting firewood while wearing an...
Expand
If you wanted you should be able to fit a valve with auto return, you might have to lose the 2 handed levers though
WWW.INSTAGRAM.COM
WWW.INSTAGRAM.COM
Expand
Looks pretty quick in that video! 😂
Expand
These are made by a friend of mine - very well made bits of kit.
Read more
