I always thought that in Winter, the sap stops flowing but it is still there.
The xylem doesn't close up nor fill with air.
Therefore, the wood weight remains the same Summer or Winter.
Happy to be proven wrong because then I would learn the facts.
A quick glance at readily available info on Google only mentions cut wood and changes due to hygroscopic nature of cut lumber.
Nothing about living wood.
Edited by Ty Korrigan
I've always thought timber was drier in the winter. No hard evidence for that, more just a feeling based on stuff I've seen and heard. Like the firewood example above, or coppicing being done in the winter because the poles last longer due to being drier, (one of the reasons). Or spring being the time to tap Birch trees for wine making.
I think there's obviously still sap there in the winter, just less of it.
Just found this.
In this very commendable book.
How can there be less unless the xylem walls either shrink or empty and fill with air?
In Spring wood appears wetter due to the hygroscopic pressure of sap rising thus creating the illusion of wetter wood.
Would it be a change in the sugar content of the cells.
Higher sugar & less water in winter to resist freezing as one would assume you couldn't just drain a living cell and replace it with air without it permanently dying?.
I had a similar theory about ADB, harsh winter seems to help the bacteria spread through the cells due to sugar, mild winter and the tree doesn't hibernate as much, so less sugar storage and slower ADB growth.
No one cares about your theories Stu.
Just get on and come up with the accurate tables for us please.
Drier in summer i think?
https://www.nrs.fs.usda.gov/pubs/nh/notes/nh_5_03.pdf
Quote
In general, the weight of a load of summer-cut (June-July) birch and aspen can be
estimated by assuming that half the weight is water. Wood cut in January or
February has more moisture and could be 6 or more percent heavier than the same
volume cut in summer.
Moisture content will vary from year to year so you should calculate it for individual
cases if you wish to be precise. In addition, if you want to compare the weights of
winter-cut and summer-cut wood, the samples should include equal proportions of
top, middle, and bottom logs because of moisture content variations within the
tree.
WWW.SCIENCEDIRECT.COM
Fuelwood moisture content is an important parameter for small and medium-sized heating plants. Optimal storage location...
Quote
Furthermore, moisture content of live trees varies with the season. With downy birch (Betula pubescens) it is highest in the spring, just before the breaking of the buds and lowest in the summer. With Scots pine (Pinus sylvestris) the moisture content is highest during the winter and lowest during the summer [3], [4], [5], [6].
