The wind blew over a big old pine tree I had. If I could stand it back up I would because it isn't dead. Anyway, it is leaning on a tree I want to keep.
I was doing some research on how to take this tree down and it was saying to cut a notch in the top and then cut a line from underneath.
Does that match your experience?
It is about 15" diameter, if I were to guess.
Eventually I'll burn it in my log burner :)
Edited by crskub
question
That's one possible way of seperating the trunk from rootplate but there's likely to be a lot more involved to 'get it down' than one cut, and an awful lot to go wrong in the process.
Have you got photos of the tree, and what equipment/experience do you have?
While not a particularly large tree, it sounds like this is beyond your experience and abilities. I’d suggest ringing someone who knows what they’re doing rather than making the situation worse or getting yourself hurt.
19 minutes ago, Doug Tait said:
Think it largely depends on whether one of these is available...
That looks like a very niche wood whittling fetish
I was just reminded of the visitor to arbtalk that thought the price he was given to remove a large hairy softwood was too much. Plucky chap was going to do it himself with a handsaw, motorcycle suit/helmet and some ladders that reached nearly halfway up the tree. That was a while ago, think he's still taking brash to the tip in his boot at weekends.
Don't mean to discourage the op here.
