The management plan for our small woodland ( a couple of acres) is in and we’re looking for a chainsaw to take on the bigger trees.   The wood is mainly overstood hazel coppice (20+years) which we’re looking to turn into short rotation stands.  The rest is planted oak/ash - we’re leaving the dominant trees but need to thin out the sub dominants and whips and dying ash.  There’s nothing massive - all under the 380mm I did the course on.
I’ve just done the CS30/31 chainsaw tickets with a STIHL 251c and am looking for advice on whether this is a good saw to buy, is it overkill and are there any equivalents I should look at?
We’re looking at petrol not battery
Any thoughts/comments appreciated
  On 26/02/2024 at 12:31, Dan Maynard said:
I'd stump up the extra and get a 261, no more weight but lots more power, much better and tougher saw as design for pro rather than domestic use. On a 16" great in the woods.
Expand
 Thanks. I was wondering about a 261 but thought it might be overkill.
second hand prices are similar to 251’s - but FB Marketplace seems a terrible place to buy - mainly around knowing if it’s actually theirs and also if it’s knackered or not.
Would say something around 50 to 55cc as for make it's your choice. The problem with second hand saws you never know the history, I ve bought quite a few saws second hand but all have been cheap and seized so I know it's a complete rebuild.
Buy new and the best you can afford from local dealer.
-Its all well and good saying this little semi pro does fine etc etc and yes, I know it will . keep a sharp chain and a 171 will do it but , Eventually you will need/want something that can do a bit more a bit quicker so why not start there rather than build up to it via 3 or 4 different saws .
Read more
