I've a 6x6m or so grassy patch that I want to put a second driveway/join onto my old one.
Can get a 3 ton digger off my boss for a weekend no problem.
Will be getting someone to tar it after I do the ground works but I was curious as to how much type one I would roughly need? And if anyone knows roughly how much it is per ton.
Would be a sheer drop off the curb on the new drive way side as I'm sure you need planning permission etc from the council and what not?
As above but consider a Terram style liner as an addition depending on your soil type, will stop your aggregate migrating into the soil and future sinking. I had always used larger hardcore to a depth of at least 200mm and then capped with type one, usually cheaper to do it like that 👍
read this first as I know someone who got seriously caught out by this !!!!
If the driveway area is more than 5sqm then you technically require planning consent even if it’s a replacement.  It’s only PD if you discharge surface water onsite.
Ways to do this include:
1. Discharge into a soak away onsite.
2. Grade the surface into soft landscaping on site, e.g. a shrub bed.
3. Make it porous. Remember, the whole thing has to be porous.  If you fit a porous wearing course on top of MOT type 1 it doesn’t count as porous due to the fines in MOT type 1.
I worked in planning as a TO for over 13 years and used to come across this all the time. I never met a driveway company that knew about the requirement.  It’s just not well known in the building industry. Suppose if no one ever told them then how would they.
The road I put in at mine with a friend is 40mm scalpings, which is similar to type 1, but doesn't meet the standards to be called MOT so couldn't be used on a highway. Can get it from a local quarry for notes....
I think official MOT type 1 has to be blasted rock?
It's laid about 6" thick with a layer of membrane underneath. Compacted with a double drum roller. I've had 8 wheeler lorries on it (so 32t) and it didn't leave a mark.
Back when I was a teenager we extended the driveway at my parents house the old fashioned way - dug it out by hand, put bigger rocks at the bottom then progressively smaller stones up to dust then a layer of chippings on top. Compacted by driving the car over it. Was fine for cars.
Here you go:
6x6m = 36m2
36x0.2m deep = 7.2m3 of stone
7.2 x 1.8 (that's tonnes per cubic metre for granite scalpings) = 13 tonnes.
Worth getting a price for it delivered in bulk from an 8 wheeler. Round here it's £35/tonne, which compares favourably with £50 for 800kg in bulk bags from a builders merchant. If you are close to a quarry then it will be a lot cheaper.
