2 hours ago, JDon said:
Aye you could be right.
Firewood fella says in a 9 hour shift on the saw I'm cutting 35 crates worth of hardwood. Some of it is pretty rough, cone split stuff as well. Messy but I'd say that's a no bad result.
You animal you ! 😁
  • Confused 1
2 hours ago, Dan Maynard said:
If it's that bad I'd look seriously at some semi-chisel, cut is a bit slower but you'd spend a lot less time filing and the chains last longer.
I've a reel of full chisel now so I refuse to buy any loops or anymore reels as I'm tight af. Otherwise I would.
@Stubby Not sure if that's sarcastic 😂
I run semi on my 261 all the time, fed up hitting rubbish in garden trees. I'd guess it lasts 4 times as long so even if you bought one loop it'd save you money.
I would if it were hard af all the time. But cutting for harvester drivers so got to be a bit quick when going.
edit
No that I'm quick. Slower than a bank holiday weekend in the cell
Edited by JDon
In production forestry you would soon get frustrated by the lower performance. When skidding out softwoods in the bad old days the guy crosscutting at the landing would used an 80cc saw with 15" semi chisel and wind it in to the cut because the dirt would knock the tip off full chisel in no time.
Just now, topchippyles said:
How many could you do in your prime stubby 😉
2 and a bit . Then sit down for a nice cuppa 🙂 No seriously it is a young mans gig and a good young man at that if you want to make any coin . I take my hat off to him . I would not last till 10:00 today .
I agree you are not a spring chicken any more 😏
