I have two separate rings on the bridge, so if I need to clip two lines it gives them a little bit of room rather than crowd onto one. Does mean you need to avoid crossing them over though else the bridge does a crazy twist that doesn't look good at all.
45 minutes ago, Joe Newton said:
The camp gyro swivel is the best solution I've found. Keeps everything oriented nicely with no twisting.
do you have you bridge threaded through one of the holes or carabiner to bridge?
Yeah but there's plenty of options to attach it to your bridge
