Best firelighters
I've seen some people put the cardboard packet from firelighters in the recycling.
They've gone out and bought a product containing kerosene, resin binder, emulsifier etc, but they won't put the bit of paper in the fire, so they dutifully carry it out to the recycling :afraid:
Edited by scbk
Newspaper, twigs, sticks and 2" square logs (affectionatly called number two's) with a couple of logs on top.
Lit with a match.
Open primary and secondary air, shut the door and get a cuppa.
20 mins later close it down to a simmer.
I worries me putting combustable hydrocarbon in a closed box ...
6 hours ago, difflock said:
My grandmother lit the fire wi a peat( turf to some) which just had had  a strone of pariffin poured on it out of a teapot(which sat in the corner of the hearth) Essentially the same as modern firelighters.
Interesting as I remember having my parents having a block of some sort of oblong porous stone with a hole down the middle of it (probably larva) with a wound wire wrapped through it with a loop handle. It was placed in a jam jar of paraffin overnight and used to light the fire the following day.
What kind of Larva? Must have been some strong bugger of an insect that. 🤣
