41 minutes ago, Billhook said:
I have four levels of wood splitting and they all have their place.  Wrists are bad now so X27 is in retirement (bit like me) so the little electric kinetic Portek hits above its weight for small jobs in the home. Particularly good for the smaller wood needed for the Aduro 9 stove
Before I built the Lockdown Splitter I borrowed this big vertical splitter on the front linkage of the Fastrac
Cone splitter on Matbro seemed like a good idea at the time.......
Then onto the Lockdown Splitter
Lockdown again
Daisy Etta  Caterpillar D7 was working well until it pushed the static axe out of the ground which was set in a ton of concrete!
I just love splitting wood mainly economic but partly therapeutic
Still find a place for the useful Portek electric kinetic though,just handy to have near the stove.
Bill , on the Portek vid the second log ( bigger in dia than the first ) when the ram hit it sounded like the pinion spun on the rack ? Just wondered why you did not take a split off center ( like you would on a big round with an axe ) to avoid it stalling seeing as how you were going to split it multiple times anyway ?
Because I am not that clever!
I'm not having that bud ! You are as cleaver as a cleaver person !
I was having a problem parsing that, clever and cleaver.
The box splitter is marvelous Bill
You do know that another name for cleavers is  "Sticky Willie" now I think I prefer Bill as the other sounds positively pornographic!
I had a 7 ton mittox electric splitter on a stand, only used it a few times on big nasty bits and it did ok. Was a faff to get in and out the shed clean it and put it away, axe and maul much more convenient and eventually sold the splitter to a friend who also hardly uses it !
Would he be interested in selling it and where is it  (i'm in Scotland so if you are t'other end of the country this is probably the most important question) ?
  • 1 year later...
Old thread bump.
Anyone ever had issues using a 3kw splitter on a domestic circuit?
Cheers
Edit: lol, look at this dopey little bell-end down there...                  ↘️
Edited by peds
8 minutes ago, peds said:
Old thread bump.
Cheers
Just don't use one on an extension lead, most are only rated unwound at 2400w
