3 hours ago, scraggs said:
I had thought of building something like this to hire out with operator several years ago.
The idea was to have the chipper on a turntable then blow into a trailer towed by the chipper truck.
A chap in Germany did that with a QuadChip. I'll find a picture......
The turntable idea is a good one, you could be onto something there🤔👍
Ive no interest in offering a chipping service tho, the thought of badly stacked brash full of soil, stones, fence posts with nails, pallets, bags of dog eggs etc just makes me cringe! We have all seen the piles of crap that you know your going to be asked “can you just stick that through your machine?”
I reckon the infeed height would do your back in if it was on a defender, on a lower truck would be better. you would have a better legal payload with a 3.5t trailer than any 3.5t truck 👍
Modern air ride suspension kit fitted to a defender may make it doable to bring high down when in work.
In theory it is a great idea. There is a QuadChip somewhere with exactly this setup. For those jobs where you leave the wood chip on the ground you don't need to be towing and if you're blowing into a tipper trailer you can load a good 2.5T of chip!
Mounting the chipper low enough is the biggest hurdle.
Paul at SAS did the TW on a defender chassis and it was on the TW stand a an APF Show at Cannock Chase. I thought he dismay it to be honest.
I should read my posts before I post - I seem to fall foul to Spell Check!
I thought Paul dismantled the TW/Defender after the show......
Defenders lend themselves to pto run equipment because they direct drive the pto off the end of the gearbox, no issues with transmitting the power. The winton type prop interrupters or gearbox side plate pto`s are only rated at about 40hp max and dont take kindly to the sort of stress a chipper would throw at it, ok for compressors/generators.
Bob
