Alternator ppr...? Anyone heard of it or know anything about it?
1 hour ago, htb said:
As you say W terminal feeds rev counter on vehicles.
But how or what do I need to put into my new clock for it to calibrate the reading?
2 hours ago, swinny said:
Right, the wires already there from the old clock so that's OK, I just need to calibrate it to read correctly the rpm of the engine...
I remember years ago using a timing lightning my college days back in 2006/7 ish, never used one since lol. Can't even remember what's what.... something else I'll have to buy then I suppose 🤔
And I always thought they were for dizzy cap timing?
Infact the wire feed is that red one on the w post that feeds the clock  to give the rpm
I was wrong about the poles on the rotor, it is one field coil but the iron is shaped to give 6 poles so the W terminal will see 3 cycles per revolution, . My guess is 3 if it senses ac with possibly just one diode. none of my working alternators have a w terminal.
  • 1 month later...
Just getting round to this now.... and I've taken covers off and found that my Alternator pulley is 70mm and the crank is 140mm
PPR = P x R /2
“P” is the number of poles in the alternator. “R” is the pulley ratio. Determine the pulley ratio by dividing the crank pulley diameter by the alternator pulley diameter
So my r value is 2....
How do I work out how many poles on this alternator? It's the last piece of the puzzle lol  😆  helllllllpppppp 😀
Edited by swinny
I would say that if you have a rev counter and can check the actual rpm of the shaft in question,  be it engine or flywheel shaft speed  , then guess at a pulses figure to input and try it to see what speed is displayed  ?
For example an alternator on a Greenmech 19-28 mk1 has a pulses per rev of 20.9 if I remember rightly.
By doing this   if you know the actual speed using a rev counter then just keep trying inputting different pulse settings until the display shows the correct speed.
I know flat out the machine runs 2600rpm or so the old display said..... I will start on this guesstimate route 😀
If it's not exact, maybe best to aim a bit high with the PPR so the computer thinks the engine is running slower than it really is. That way the stress control will cut in early, rather than other way round and stress control cuts in late.
My dad bought a tachometer from Machine Mart a few years ago for his boat engine, don't think it was hugely expensive.
PPR = P x R /2
Are you trying to setup the stress control? If so just use the actual engine speed and forget about the multiplier in the tacho for PPR. I.e you want stress low to come in at 2200rpm and stress high to come in at 2600rpm engine speed then you can have the tacho and stress control unit reading incorrectly but they actually function correctly. If your engine is doing real max revs of 3000 and the tacho reads 2200 then just setup the stress for it to work at 2200 max revs correctly and it will be fine.
There is a bandit list somewhere with their models, engines and PPR settings which I found once setting up my 150 stress control. Of course I cant find it now!
