White smoke coming from exhaust on Stihl 201TC
Connie bashing all week, this afternoon my 201 started blowing white smoke, really smelly as well.
I run it on Aspen and have done for a while so can't be bad mix. Any help on what could be causing this and how to fix it?
Other than the smoke, the saw seems to run and cut fine.
Edited by Blah
Someone yanking your chain , put a bit of diesel in there ?
20 minutes ago, Dan Maynard said:
Or someone filled fuel with chain oil and then tipped it back out. I've heard that can make it smoke for a tank or two, apparently, never seen it myself obviously, honest.
That's more likely than the diesel.
Thanks for the suggestions, but it's really not fuel related. I'm interested to find out what else could be causing this.
Air, spark or compression then. That’s all there is. I’d still say fuel.
Or something like chain oil dripping onto the exhaust maybe.
16 minutes ago, Pete Mctree said:
If it is producing white smoke when running at normal temp, then it is burning something in addition to aspen and 2 Stoke mix.
Rinse the tank out, add fresh fuel & try again.
Whilst I agree in principle, in reality that's not the case. I have an old hedge cutter that's really smokey (old hs81 r) and that's only ever had decent fuel in it.
