Supposedly decks are rot resistant which is something that never seems to last that well on many mowers
Quote
All HRX models feature a NeXite deck, made from an extremely durable polymer material. Honda is so confident in the durability of the NeXite deck, it comes with a lifetime warranty.
Honda cost a fair amount and usually for a reason. I would apply 'you get what you pay for ' in the circumstances. Look after it, wash the deck out, do not store fuel in it a d it maybecome a heirloom! List it in your will...
I got a mate who is a rep for Etesia, they have always impressed me too. Once saw an old rep put a brick end on the floor and smash it to dust. Deck survived with a few scars but it still cut. Think they were Kawasaki engines and the crank survived too! Council buy them by the dozen which is a marker on quality and strength too.
As above, kaaz are good
1 hour ago, difflock said:
An nobody is suggesting alternatives?🤔
Thought you had quite a bit of grass, have you looked at wider mowers, or a robot?
kaaz mowers are heavy but good
blade that comes on them can break as its vented on ends but stick a high lift solid one on and they are better
treat engine to oil every 50 hrs and last forever
can loose drive to a wheel but theres a wee pin inside wheel that breaks and saves drive/more expensive bits and its beyond easy and cheap to fix
worst case you hole the deck get away with a wee thin steel patch pop rivited over - lasted 3 years like that so far
Etesia were shit for me. The Kaaz/Honda/Lawnflite design is pretty good- fan assisted collection and a blade brake clutch. If I were to go back to pedestrian mowing I'd have a wheeled version as my main mower.
Edited by doobin
1 hour ago, doobin said:
Etesia were shit for me. The Kaaz/Honda/Lawnflite design is pretty good- fan assisted collection and a brade brake clutch. If I were to go back to mowing I'd have a wheeled version as my main mower.
Doobin,
Why?
Do they do a tracked varient?😁😁😁
P.S.
Thanks for the useful suggestions, the side discharge JD I bought to cut the rough grass in among the wheen o fruit bushes/trees, is driving me mad wi the swards it leaves.
So I need a bagger.
Edited by difflock
