Thinking of a bulk bag delivery truck, currently using a trailer, which can be tight getting into narrow driveways with parked cars. I was thinking a HiCap Defender might have the load capacity, but would two bulk bags fit in the bed?
Van with a winch at the top of the bulkhead and a pulley above the door. Lift stuff in. Unhook the pulley if you want to drag the bags deeper into the van. Reconnect the pulley to pull stuff towards the doors and lower out.
Expand
Depends on the size of bag but the bed won’t be not long enough to take two common size 90 x 90 x 90 bags with tailgate up but it might take small ones, no problem weight wise with seasoned logs. You can just fit two bags 90 x 90 x 90 into the back of a single cab Mitsubishi L200 single cab with tailgate up and the bed is 2.15m long which is longer than the Landrover. Volume wise if you empty the dumpy bags and net the logs you may be alright.
Edited by Vedhoggar
Read more
