Well, how long does it take to make a cut like that? 10 seconds max? Do you stop for lunch and a battery swap? I don't do apple pruning on a commercial basis, last year I probably only did about 30-40? I didn't use a chainsaw for more than 10 minutes for all of them put together so I would be quite surprised if you did 40 minutes of finger on trigger cutting before lunch but like I said, I don't do commercial so I have 0 idea how you prune! 😂
Outside of that it's a 201c-m if you want petrol!
I concur. They're the only chainsaws from a general building tool maker that are actually a chainsaw (as opposed to a tool that looks like a chainsaw and broadly works like a chainsaw but is nevertheless not a proper chainsaw).
Ah, they're the only general building tool maker that bought a proper chainsaw company up too (Dolmar) so it kind of makes sense. I have Makita battery toppers, I'm a fan too.
I'd go with the 18v Makita if the stems are wrist thickness, it is so light, think they do a rear handled version which will be better for control. Or the battery Echo is excellent apparently but more money.
What time is lunch?
We're on docky,09.45 ,dinner,12.30 ,tea after 4 pm.
I will be cutting all day and grafting once they are all prepped.😁
10 hours ago, Pinkfoot said:
Those trees are Gala and the owner is changing them to a very red gala .
That is a very brave move isn't it?
I thought even proven red sports are prone to reversion.
It's an Italian clone I think "Schniko Red " I think it's called.
They can get too red for the supermarkets,!
It's still a risk though ,supermarkets may change their minds
I have some giant loppers  but the trees might too  big diameter fot them
WWW.LAKEWOODPRODUCTS.CO.NZ
Pro-Pruner loppers, tools designed for forestry pruning large branched trees up to 65 mm. Loppers are complimented by a...
p100-pro-pruner-loppersforestrytreepruninglopperst.jpg?i=-dJETfKBd23LP3qyJpBn2vh5OO5Kjwy0beUvZX964WBDGluY7dwuKimPIOErDovShGGOi5O77aUJIZ0clWzeURZfv0xls8_n0x7E5yUh_9n-KcAvtZFC92gpb-AABcG7cYINA1dBPEZ4FR11I6ziUK06Jd6fu_u9ZMtPVEsRCQue4F0EGNElQpM6uQGzkjfQcwstCZK64XDnS6Qg5RawZ65NUlNPA0rQDXGMX8IfadNml4BayuHw1ySsoIl44_EQAk6dS8sTK6ghXI09vi00sQ~~
But they do cut pretty big stuff compared to other loppers but probably only about 45mm comfortably.
Agree about using a 1/4 chain  for a finer finnish.
Edited by Stere
Thank you for the offer .
Loppers are a bit brutal in this application,the anvil crushes one side of the stem and bruises it so a saw is the best solution
You need bypass loppers, not anvil ones.
