Are you using the new two rope technique when you climb?
86 members have voted
  1. 1. Are you using two rope technique when you climb?
    • Yes, nearly all the time.
      9
    • Almost never.
      77
This poll is closed to new votes
  • Please sign in or register to vote in this poll.
  • Poll closed on 25/02/21 at 16:57
45 minutes ago, Mick Dempsey said:
But that means for a 20 mètre tree you’d need 80 odd mètres of rope to reach the ground on ddrt, which is a lot.
Joe beat me to it, you can pull one end through and revert back to your original rope length.
I’ve hardly ever done this, as Huck said, a big loop of rope is not something I particularly want up a tree.
I occasionally use a secondary system when it suites to make my positioning to make a cut or set rigging easier or safer probably could count on 2 hands how many times a year that it happens and I climb 6 days a week so that says how often it happens
Not when you're bombing limbs off, but if you're doing that you probably don't need a triangulated system.
I'm talking about using it for tippy reductions/deadwoods, where if you drop something into your line it's no big deal
Ah, ok.
I’ll never need it then.
