Are you using the new two rope technique when you climb?
86 members have voted
  1. 1. Are you using two rope technique when you climb?
    • Yes, nearly all the time.
      9
    • Almost never.
      77
This poll is closed to new votes
  • Please sign in or register to vote in this poll.
  • Poll closed on 25/02/21 at 16:57
8 minutes ago, Mark Bolam said:
As long as you can still reach the ground I would say that’s fine.
Pretty sure that's not actually a requirement, hence the need for a knot in the end of your rope. Crazy, IMO.
You can always reach the ground . Its at what speed that is important 👍
Edited by Stubby
  • Haha 7
11 minutes ago, Mick Dempsey said:
But that means for a 20 mètre tree you’d need 80 odd mètres of rope to reach the ground on ddrt, which is a lot.
No, only one system needs to be able to reach the floor. By unclipping the tail I'm back to my main system and able to get down
Is this new? Was never a requirement in the old best practice.
27 minutes ago, skyhuck said:
Both ends, old school.
It's got too work for me. Carrying a second line around is impractical and frankly, completely gay.
The option is always there for me if I need it, but doesn't get in the way when I'm not using it. Takes less than a minute to pop a second system in.
I don't know about the old days, but from what I understand of the new regs, only one of the systems has to be able to get you down, so if you were working with two lines, or a main line and a backup, only one would have to be long enough to get you down.
I could be wrong though, I'm sure Paddy numbers will tell me you.
In the past it was always seen as acceptable to descend , stop, reroute rope and then complete the descent, hence the need for a knot to stop you dropping off the end of the rope. Not something I've ever done, always used long enough rope and never had a knot.
I've misjudged it a few times and had to get the ladders up, or drop the last metre or so.
I don't bother with a stopper. Occasionally a well meaning groundy will tie one for me when I'm climbing 🙄
