Petrol has got to be handier for that size engine. Less vibes, less weight, easier service. You’d need to burn a lot of fuel to make up the price difference between the two engines as well.
I have just taken delivery of my Skarper C90 and what a bit of it is. The way it pulls branches through is impressive for a chipper of this size with no drum feed. It will chomp through stuff 3" thick no worries at all, eats Leylandi up and generally gets rid of everything that is chucked in there. Plus the size of it makes it a winner in my opinion.
So what are people's feelings about the relative merits/disadvantages of engine under infeed (Rock 13hp, skarper c90 pictured above) vs engine over drum (CS100, Rock RX13 etc etc). Is the infeed significantly higher to allow the engine to be mounted beneath it? Is stability Improved?
