Evening,
has anyone built a drying cupboard for wet/dirty gear? What sort of heaters have you used and are happy leaving them unattended overnight? The Mrs patients is starting to wear thin with trousers in the hall way in the rad.
Thanks
4 minutes ago, Mike Patrick said:
Evening,
Thanks
Mine goes round the log burner
13 minutes ago, Mike Patrick said:
Evening,
Thanks
I had the same trouble so I had a mate who's a plumber put one of those long new style bathroom radiators in the garage  and I brought an big second hand wardrobe and just fitted it around the rad and cut some slats out for air circulation worked a treat till I got divorced and sold the house.👌😂
In the workshop I’ve got open cupboard type arrangement with an oil rad with a metal rack a foot above it for gloves and boots and a couple of coat hangers / hooks for jackets / trousers etc. Works a treat
That sounds like what I’m after. Any pictures?
If you want fast drying you need a dehumidifier. If you put wet stuff in a hot box the air gets humid and nothing dries. I put my stuff in a small room with one of these. It drops the room humidity to about 50-60% and things dry very quick. The tank is usually full pretty fast!
WWW.APPLIANCESDIRECT.CO.UK
Buy electriQ 20 litre Low Energy Anti-Bacterial Dehumidifier for 2 to 5 bed houses WHICH Best Buy CD20LE from Appliances Direct - the UK's leading online appliance specialist
