The trouble with get little cheap stuff to tide you over till you can afford the bigger stuff is that it holds you back without realising it.
Get yourself a good 30+ hp 6’’ minimum chipper, then you’re in business, otherwise you’re just a gardener.
23 hours ago, Dan Maynard said:
It's been said before it's confusing how the old 150s command such a high price. Seeing as the design is over 20 years old you might think they have been improved on and well, they have. Newer chippers get through stuff faster.
The only good thing I guess is if you come to sell it on in a couple of years then you should more or less get your money back (unless we're all in recession).
Similar question in a way for me as not full time, I've gone for gravity fed chipper. Much cheaper to get a reliable machine, I just couldn't justify the money to buy and insure a big chipper and worried that if there's a repair bill on hydraulics, flywheel etc could be thousands.
Realistically for 90% of what I do, smaller trees, hedges etc M500 is absolutely fine and if I get a bigger job on then I hire in a TW230 for a day.
So I'd say no, don't buy a ragged old 150 but rather start with a CS100 or M500 if you can find one and then chop it in when you eventually go full time and the business warrants it.
Maybe depends when that will be I guess.
Gravity fed chippers are under rated, loved the old ArborEater  ?  k
55 minutes ago, Treetom15 said:
I’m lucky in the sense that I have access to a hire company locally who will supply 230tracked or tr6 for £100+vat for the day, which is cheap IMO! Re the cs100’s....I’ve used them, and personally if I was going to spend 2/3k on one I’d rather put that money towards something that will actually chip decent stuff ? they for sure have their place but I’m fairly rural and most of the work is usually decent sized tree/timber so you’d max it out very quick! The 2nd hand market recently seems to have gone crazy, I’ve been offered a 2010 Jensen A540 tow behind for £8400......seems like a lot but it’s a much larger machine?‍♂️
Thats a good rate - if it arrives ready to work.  K
That's Isaac Newton For ye !
They are good chippers, a firm I sub too have 2 of them, I’ve subbed to him for 10 years now. When I started the older 150 was reading 2800 hours and the clock hasn’t worked since I’ve known it! I’d say it’s on at least 4K hours now (probably more) and it still chips and does the job. A good advert for Timberwolf and I just hope the new ones are built aswell. There are better and faster  machines to buy nowadays but if your handy with spanner’s there’s nothing you can’t do on them yourself. Sounds like 6k probably a bit high on the price for that particular machine though
