Tracked chipper on a tipping trailer?
billpierce
I have the same trailer and normaly I go really slow when the point of balance is beeing passed. This makes the tipping motion really smooth.
One heads up with tracked chippers and Brian James ramps is to be ready to floor it when exiting the trailer in wet or icey weather if one does not want to slide of the ramps.
Sounds lovely 😂 I’ve not found any issues with getting it off in the rain, but have found it slipping getting it on. Perhaps not standing on the chipper when unloading would help. I guess it would mean it reached the tipping point slightly earlier and so have a shorter drop?
Going slow is essential.
3 hours ago, josharb87 said:
I found that just screwing a load of self tapping bolts to the ramps helps no end when wet.
And not using the support legs when loading pushes the back of the trailer down decreasing the break over angle
I never use the support legs when loading - too much faff.
However, it is worth pointing out that it is possible to lift the rear wheels of the tow vehicle off the ground, which can lead to everything rolling away if on a hill as they tend to be the only braked part of the combination…
