Which Friction Lowering Devices?
Jamie Jones
Just starting to get in to getting a rigging kit together and I have been looking at which Friction Lowering Devices to get?
The only one I have used to date is the Tree Runner P500 Rigging Device / Abseil Brake that is attached to the tree with a Ratchet Strap. The Device has rubber feet so you don't damage the trees stem...
Do people rate this device?
I was wondering what Friction Lowering Devices people use and what they would recommend getting?
RC 2000 is almost as good as a bollard and nice and easy to set up , maybe a little cheaper than the p500 ,I would definitely take one over a port a wrap for serious rigging.
You definitely can’t go wrong with the rc2001 for a fixed bollard .
you have the choice of changing to rubber mounts , I’ve rigged out some very big trees and lumps with them and it was my go to device before I got a Hobbs.
The pinnacle of lowering is the GCRS but it’s expensive and not as robust as the hobbs , well in my hands any way...
You won't go wrong with the Runner or the 2001.
Dan is spot on about the portawrap.
Whenever I see people using them I cringe, it's like using a bow saw.
I always like the back up the bollard with a whoopie sling at the base to back up the ratchet strap.
Hopefully you will go for a GRCS then sell it on to me for £50 after a few weeks.
What Mark said with a whoopie or dead eye under any ratchet strap device, or just wait for the moment a big lump sees it head up the tree if not cut in........embarrassing
I think you can still get a tongue/foot hook thing for the p500 which is easier than cutting in.
Edited by Andrew McEwan
I would go for a fix bollard over a floating device any day. We have the tree runner, its pretty light and works great.
In the past I have used an RCW3001 which is bomb proof but heavy, not used the 2001.
Just a scaled down version of the 3001 , but still meaty enough for take downs in uk.
