I’ve managed to find an older Opico skidster fitted with a yahnmar diesel engine for a good price. Very tempted to take a punt! Doesn’t come with a grab though, where can I buy a reasonably priced grab?
This is where people f up.
The grab makes the machine.
No one sells them ‘due to upgrade’ because any grab on these titchy machines is maxed out already.
Any grab is better than no grab, but if you find anything for less than £2k you’ve done well.
10 hours ago, Little Butch said:
I better get saving then! The grab will almost cost me the same as the machine 🤣
You should be able to find cheap grab as they are not that powerful machine, even a cheap Chinese one may do.
A grab won’t cost a fortune if you shop around. I’d check local dealers for second-hand units first.
Just confirm the hydraulic flow and pressure so it works properly.
  • 2 months later...
On 19/06/2025 at 12:20, doobin said:
I didn't realise that about Holmbury! Bastards!
Hydraulic fittings are often referred to as '3/8' or '1/2' body but this is a terrible way of doing things and it drives me nuts that people do. Basically, no part of a '3/8" body' quick fitting measures at 3/8". The thread may indeed be 3/8" bsp, but it could just as easily be 1/2" bsp, metric 12L, or 7/8 JIC on the same fitting!
Two main standards are used to ID the body- or rather, should be used. Even buying from 'hydraulic specialists' I've had the wrong thing sent. These standards are ISO and DN.
For a Sherpa you need to ask for a pair of DN06/ISO10 couplers with a 3/8bsp thread.
Right, so coming back to this, my hydraulic couplings haven't got any easier. I can see some writing stamped on some of these parts: DNP PLT 4 ISO10M - M19 ITALY and DNP PLT4 ISO10F - I19 ITALY.
What's confusing is that the two sides don't look the same. This might be because my grab isn't a standard part; it was fabbed up to fit my Sherpa from an Intermercato grab by the previous owner.
I'm looking at buying
WWW.LSENGINEERS.CO.UK
Overview: The Manuli Female Half Only 3/8" BSP Quick Release Coupling is a genuine Manuli part for reliable fluid transfer in hydraulic and pneumatic circuits. Built from...
 and
Anybody care to comment on whether they will or will not do the job? What's going at the black bracket end there? Is that a different part I will need to replace as well?
Also @doobin and other Sherpa owners, does this look familiar or are your couplings different?
Edited by Blah
spellings
Sort of answered my own question there, by getting some spanners out and taking the fittings apart. Turns out one end is 3/8" BSP and the other (grab) end is 1/2" BSP. I think. And, in case it helps someone else, these fittings are all female; at one end (bottom of the picture) on mine there's a male to male adapter.
Ordered some stuff. See if it fits.
Turns out one end is not 3/8 BSP, it's metric M18 x 1.5. I can see why the fittings are mismatched now. No one makes a coupler that is 1/2BSP on one end and M18 x 1.5 bulkhead fitting on the other end.
More stuff ordered.
New hydraulic fittings fitted
Apart from being shiny, they seem to work a lot better than the old ones, though I haven't used them in anger yet.
They take up more space, the assembly is considerably longer than the old ones. The result of this is that in certain positions, the hydraulic hoses are on a quite tight angle. I'm guessing this is fine; it'll have to be.
Ordered Manuli couplers from LS Engineers, and various adapters and washers from Burnett & Hillman.
