And sitting down can be the problem drivers tend to get a sticky bum and stay in the seat when they should get out and clear or load by hand, also working in the rain or snow is far more comfortable standing up, the view of the tool is much better and they turn in there own length, with no loss of lift capacity on turning for small areas stand on skidsteer is the way to go, as for wheels or tracks
Is it bollocks! :)
When you’re doing repeated cycles of moving stuff why would you WANT to stand up.
But we don’t do repeated cycles no one spends all day loading as like quarry or yard, I have both on a bit of rough ground standing is infinitely more comfortable. And standing for me is far more productive especially when I’m paying wages
20 hours ago, doobin said:
Those opicos looks great, just a bit too wide for me. Really tempted by a secondhand one but decided to spend double on a new Sherpa and know that I can get it in more back gardens.
how do you find the sherpa?
Only had an hour on it but liked it. Design dated admittedly but steel where it counts and easier to drive/handled the weight better than a cast for me. Both looked very well built
machines. Much less twitchy on the levers too with a full load, and a slightly higher tipping load. Both had parallel lift.
I tried the yellow ‘small’ version rather than the red ‘Agri’. For an extra grand you get electric start and bigger pump
and wheel motors. It really did push, even on skinny tyres into a pile of crushed concrete.
close to pulling the trigger on the 100 diesel, with a stump grinder and log grab and skinny tyres
For me I didn’t need the extra flow rate of diesel and certainly didn’t want the extra width. Will be interested in how the stump grinder performs.
As of yesterday, I’ve now rolled both brands and both engine choices. The lovely little Honda only needed oil daubing out of the cylinder to stop it hydrolocking and then fired straight back up. Did the rest of the day and all today. Ne’er a grumble. The diesel one last year just worked after being left upright for an hour. Did lose more oil from that one. Real world consumer advice there.
