A given weight of wood can only produce so much energy so while 1 large log split into 2  may last longer than the same log split into 4 pieces , it should only produce the same amount of heat but spread over a longer time.
Yeah but seems to me at least (no proof) the less dense softwood naturally burns faster than the more dense hardwood so to get more similar burn rates (power output) I use larger logs of lighter woods (less surface area) and smaller logs for the more dense wood.
you do need turbulance in the firebox to ensure a nice looking fire,   to get that load two or three logs at a time,   size of these logs will depend on your firebox size.
If I am processing logs on a 4 way split then I want a length on the outer (bark) edge of the triangle to be no more than 150mm.,  so about 600mm max circumstance cord split 4 ways.
Length wise cut the width of your firebox less 50mm,   if cutting to resell 250mm will suit most stoves.
A
  • 3 weeks later...
I remember seeing something online around 12 years ago where the University of Bristol had worked out 4" is around the optimum diameter for a log.
I don't remember what the rest of the parameters were though. Slow burn, fast burn...
I tend to like a slightly smaller log. Maybe around 3" diameter. I often split existing logs again to build the fire up again if it's a bit slow or just chuck a bit of kindling in.
I do find picking up logs abt 4" is abt right. Anything bigger is an effort.......... K
Edited by Khriss
@Danny Boy probly balance between sapwood and heartwood...
