Cant give calorific values but can give you the probable weight per m3 of the two from the HMSO handbook of hardwoods.
I thought most hardwoods around 4 kWh per dry  kg
European oak goes from 670 kg/m3 to 720 kg/m3 at 12% moisture content
Hornbeams average weight is 750 kg/m3 at 12%
Odd can't find it anywhere though I thought i'd seen it in some table before.
East hop hornbeam btu in USA.
WWW.ENGINEERINGTOOLBOX.COM
Firewood and combustion of wood heat values - for species like Pine, Elm, Hickory and more
Alot of places just say its the highest  kcal off all native euro hardwoods.....
Holly is higher.
I have a chart in a book but I am working away so can’t post it till next week.
Edited by The avantgardener
The figure we used was 18.6 MJ per oven dry kg  which is 18.6/3.6=5.17kWh. Of course you never burn oven dry wood so if it's at 20% mc wwb then you only have 0.8kg of oven dry and you have to subtract the heat carried away in 0.2kg of steam.
In practice there is more variation between different parts of the tree than between most hardwood species, bark having a high ash content for instance.
Softwoods tend to be about 5% higher because they contain more phenol like compounds
I couldn't find hornbeam in the phyllis database, if you do look into the woods there you will see there is a wide range of values given  even for the same species.
https://phyllis.nl/Browse/Standard/ECN-Phyllis#hornbeam
