Finances Is a great tool. Terms seem nothing when you take them out. Then later down the line it can get annoying esp with other things on finance also.
I'd look to see if you can afford it even in quiet times. Look at what work you have on and forecast for works.
Interest rates should be low and best time to borrow but still might not be right for you?
Weigh it up first is all I say
I only wanted to borrow a couple of grand. Got a grand deposit.
Need a reliable 4x4 vehicle which will pull at least 2.8ton
Finance company I spoke to last week advised me to get a credit card instead, as they only lend 5k minimum.
[emoji106]
Thats bit low fr a reliable 4x4. Unless yr topping up yr funds. I would be looking at 6 grand. An yr getting more fr yr money. K
I'd love to, but I'm small scale and couldn't afford that.
I really don't like being in debt unless I'm absolutely sure I can cover it.
Need a wee chipper and a B+E soon too, so it's all budget stuff I'm looking at.
[emoji106]
If your borrowing small amount the interest rates are bigger.
A 3k 4x4 might not get you much, maybe some hassle also... If you look carefully you might get something half decent but with all price ranges of second ha d vehicles it's a gamble.
Would it not work out cheaper to borrow a larger amount so less Interest so you can get your truck, trailer license etc all in one go then your up and working earning straight away?
Rather than bits here and there with finance and waiting? All thats being done there is affecting your earning capability
If yr off roading a lot- a good 4x4 will pay fr itself . But a shit one will just eat yr money - caveat emptor mate . I would go fr Hilux as they better on road and more reliable - Landrovers are fab ( way better n tougher off road ) - but spanner- hungry ! K
Buying a 4x4 for that money is buying a money pit imo finance more and get something remotely reliable it will cost less in the long run!
I know a lot of the lenders I deal with have a minimum advance of £5k, but I also have plenty that have no minimum.
What you might find though is that rather than coming up against minimum advances, your budget will mean you are looking at older vehicles, and then you will struggle to get anyone to lend due to the age of the asset. For cars etc for example a lot will say no older than 10 at end of term.
Contract hire was mentioned above, but I would strongly recommend you avoid that, as it’s not as easy to exit as with an HP deal.
Also Close Asset Finance mentioned above they have recently tightened up their underwriting so less likely to look at bad credit. Although not sure how bad you’re meaning...
Asset finance tends to assess credit a bit differently, so you might be ok.
I’m a broker - would be happy to have a chat and look at your options if you like?
