This topic  has probably been discussed lots before on here but I’m unsure which gear to buy and hopefully someone can give some pointers .which cheapish good pulley block for medium ash takedown rigging and karabiner which attaches to the webbing sling.
must fit the usual 11.7mm rope
many thanks
Are you rigging with 11.7mm climbing line?
I advise starting with a decent ports wrap or bollard - you can natural crotch the crown if needed with one.
Perhaps investigate rigging rings as a cheaper alternative to a block
It’s only a medium sized ash, basic rigging gear could be just an old climbing line, use the trees crotches for friction or wrap around the trunk. That’s as complicated as it needs to be. You could add in a pulley at the top so you can pull cut branches up if need be
Hi yes not particularly big tree but got stuff underneath to dodge.dmm pinto pulley any good for this? rated at 50kn which I think is half a ton
The minimum breaking strength of the large pinto is 50kn which converts to 5000kg.
( just add two noughts to the KN value to get the KG ) That’s half either side of the pulley which takes you to 2500kg. Work in your safety factor of >5 and that gives you a WLL of 500kg.
The pinto is a good economic pulley for light rigging.
( flying capstan are an arse. Get yr fitter mate to weld up a drum bollard n hold it on tree with lorry ratchet straps) )
Edited by Khriss
