Question
Hi,
Got a job on three trees where a couple of telephone lines are impeding the work required to reduce the trees.
Anyone got any ideas on what I can do with the lines?  Spoke to Openreach and they say I most likely need a survey as well as the charge to take down the line then replace which seem really expensive.
Any thoughts or suggestions would be most appreciated.
  • 0
19 minutes ago, sheph said:
Hi,
Are the lines connected to the property(s) you are working at?, if so disconnect them at the house, take a photo of the wiring so you know how they go back.
  • 0
27 minutes ago, sheph said:
Hi,
Only 2 your lucky has 10 going through 1 tree once
  • 0
Hi eggsarascal,
Lines going from one pole to another....rather than to a property....
Woody Paul, if there were ten lines I'd have declined the job
  • 0
Just now, sheph said:
Hi eggsarascal,
Ok, I think you are going to have to work around them or get Openreach in if you can't establish where they are going.
  • 0
Contacting Open reach is a nightmare. In my experience you can't do it unless it is your line and then you have to do it via your provider.. As I had to explain to an irate neighbour last week when one of our teams snapped a line...
  • 0
But be quick, they get a bit peeved if they catch you :D
  • 0
11 hours ago, sheph said:
Thanks eggsarascal
Thought it was worth an ask....
Not so sure about newer lines, but it used to be that there's only a couple of wires that actually connect within the house junction box. These sometimes connect with a little gel filled crimp type connector (which are also dead handy to mend a broken line temporarily). Or so I'm told :$
