hp transition hp ultra
leonid
Swapping oils ?? Yeah no bother , just don’t expect a smooth transition if your switching to an alkylate fuel or back to pump fuel ...saying that if the saws not done much and is less than a few months old that would probably be fine too.
After looking at your other posts on other threads, you say buying saw from Moscow, ? Are you from Russia ?. If you are ? it would explain the bad translation.
If if you are asking to change from stihl hp to ultra oil mixed  in petrol. This is ok. ?
it would be better (easy for us to understand) to find someone (Russian) to read Google’s translation first.?
Edited by Wonky
Smile face and sunglasses
46 minutes ago, leonid said:
The fact is that the naga on the piston is peeled off, and they are teased on the piston.
Leonid I do not think people on this forum understand your question.  No one speaks Moldovan or Romanian.
Are you saying you used Stihl Ultra two stroke oil and now the piston has seized/motor incautado? Yet before it ran well on Stihl HP oil?
