Wow!  This thread grew legs since I last looked at it.
Can only find one picture of serious blow on the computer, taken by the harvester driver.  I'm the little orange blob in the middle of it.  Serious blow is best described as "challenging" and it seems a lot of people are worried this is what you're getting yourself into.
By the sounds of it you're not actually going to be dealing with any serious windblow events - the landowner will do that, so you're really looking at single and a few trees down at a time which should be bread and butter to your cutters if they are experienced enough (no need to post a cv, I'll believe you have access to proper cutters).
FISA guides, as I think I said before, are a pretty good starting point for generic stuff, and available for free from the FISA website.  Other than that, as said before, shut the trail first, keep it shut until the hazard is removed.  No lone working.  Cutters to be fully PPE'd up.  Saws and equipment to be in good working order.  Emergency access agreed - location, type of access (4*4? Mountain Rescue? Helicopter), nearest hospital etc.  Assess tension in stems before and during cuts.  Restrain root plates with winch if required.  Re-evaluate after each cut.  Banksman/woman may be required.  All these in no particular order.
Great, thanks for all the info lads.
Yeh the area we lease just isn't big enough to have a major event that we would be responsible for.
Think i have everything i need now.
Cheers to all.
And if anyone wants to get involved with the project you would be most welcomed.
  • 5 years later...
I just went to look at a job in someone's back garden, 4.5 easy-enough ash to take down. He asked while I'm there, could I have a look at some fallen trees up in his field?
Big trees, well beyond my paygrade. Biggest one is close to 100cm across, 8 or 9 of them in total. I recommended a couple of people better equipped than I to have a look.
What machinery would you need, minimum? 12 ton digger with a grab, maybe even a pair of them?!
Access is shite... long walk across a boggy field, a digger could manage it obviously, but not much else...
Depends what he wants to happen with the wood and how much time you have. Could be that you just wheelbarrow a big saw and your lunch across there.
It depends what the owner wants done with the wood.  the minimum would be just to cut them off the fence to allow the fence to be repaired.  The maximum would be removing all the timber. Access might be much easier in the summer.
four and a half ash to come down?
Where is that? Looks like leitrim soil! (Or lack of)
I had a client looking for big lumps of softwood to carve large seats. 100 cm is just about big enough. 3 of them 4 meters long.
Thought I'd have come across something by now but it's been all garden work for me this last while.
