On 23/07/2023 at 21:59, Stihl123 said:
Thought I'd try lasers
Should save a bit of measuring!
Looks a tidy set up, was that put together by yourself or is it kit ??.
i put it together myself, all the laser stuff came to just under £100, not bad at all
let me know if you want to know where and what i got
I have probably asked before, but what mill is that?
On the sawmill, cutting some softwood and the blade seemed to be jamming in the log then riding the clutch, resulting in the clutch getting very hot.
Thought blade was done so swapped it out, but still doing it.
Did couple of cherry logs the other day, absolutely fine. They were down about 4 yrs before I milled.
The softwood has been down about 8 months
Any ideas please
Edited by Stihl123
Any ideas please
How many hrs has it done ??
Might be worth checking you’ve had no stretch on the throttle cable ie it’s definitely running flat out and the  clutch is fully engaged. Poss worth cleaning the clutch out too. Softwood I find  is often harder to cut than hardwood a lot depends on moisture content. What hook angle are you running on the blades?.
not many at all as only just got it.
i did adjust the throttle a little as it has stretched a couple of mm
i'll clean the clutch out and see if i can see anything going on in there
defo is pretty wet timber
they are Ripper37 blades, which i believe are 10 degrees
thank you
2 minutes ago, youcallthatbig said:
try a blade with a bigger set to the teeth, sounds as tho the fibrous nature of softwood is binding on the blade, giving you better clearance so less drag...
brilliant, thank you. i'll get some on order and give that a go 👍
