Thats amazing! And the owner did not want it back?
Did it actually produce Walnuts?
He had most of the smaller bits for firewood. I helped ring up as he only has a handsaw[emoji15] .
Quite some rot too, lots of hollow bits, the stump was also pretty rotten. He was going to burn the lot, I will return him some nice bits in couple of years..
1 minute ago, AJStrees said:
Knocked up some 4x4 chestnut posts. Milled slabs and then used the edging mill to make up the posts. Quite easy when you know how.
When you " know how " has a lot going for it 🙂
Hate to piss on your chips but they will warp like you wouldn't believe!
Never had any Chestnut, looks V nice... so is that horse or sweet ?
I see you have the saw lying back in the mini mill, I seem to remember a  video.. probably one of Rob's, where the saw is mounted leaning about half the angle the other way, just a tad past 90 degrees meaning the way that the teeth contact and slice through the grain is different / cleaner and gives a smoother cut.
I know it feels a bit more awkward holding the saw like that but I think there is a difference.
Had a quick look on the chainsawbars  site, only really a couple of videos videos of him cutting vertically but now with his Panther equipment, you can see at the start of this one that the bar is very slightly past the vertical but from memory the Mini mill vid I saw it was a little more pronounced, anyway works for me, cheers.
LOL! Well there's a first time for everything..... I was playing about really to see what it would take.
I have a woodland full of chestnut overstood coppice so there is a fair bit the play with.
Sweet chestnut. Its nice to mill and like the colour.
Yes I done the 90 degree angle and other angles on the mini mill. I haven't used the edging mill for a while and was having a go at different things today to see what could be achieved. I took down the tree last year and its been waiting to be cut up since then. I find winter is a great time to get milling apart from the rain.
