On 14/03/2019 at 18:14, Erik said:
The fact that their wood is extremely brittle,  and hard to work with was probably what saved them from extinction.
I read something years ago saying that much of the timber from these had so many shakes from felling that it ended up as shingles. I remember a photo of a trench filled with branches that they'd felled a tree into, in an attempt to prevent shakes - extraordinary lengths to achieve usable timber!
Hi, I have quite a bit of cherry to mill for myself, about 18-24 inch wide by about 4 ft long. However the few boards I have already cut are splitting and twisting like heĺl, this is despite me pva ing the ends and boards being laid flat on stickers. Also I have some small 4 inch diameter by 6 inch pieces that I'm hoping to use on my laith, however these are also splitting badly.
So just what is the best way of drying cherry ?
Cheers
H.
Cheers
H.
I've never had any timber move whilst drying as much as cherry. One tree that I felled a few years ago split whilst drying and the split ended up 18 inches wide on a 9ft board. Extraordinary.
You won't stop it moving. Just stack well, with weight on top and hope for the best.
21 hours ago, billpierce said:
I've always used 50:1 of good quality stroke oil (Jaso fd) never had a milling saw seize. They are perhaps tuned slightly rich I.e not right up to absolute max rpm out of the cut. A pal with a 3120 runs 40:1 in his. Also not had any bother.
You will probably get a whole range of answers, I would er slightly on the side of caution as whatever saw your going to use will be run flat out for a extended period of time. But if your saws are issue free, tuned properly and you use a good 2 stroke oil you'll be reet
Thank you Bill and Saul, thats what I was looking for.
Cheers
H.
yes there is.
reeeaaaallllyyy slooowlllyy.
end seal and keeping it out of the elements so it dries at a slower rate and hope like hell it works...
All the above is sound advice to follow.
However, if the tree is vertical and balanced...
This is my coffee table,
I felled the tree in August last year,
Milled up within a couple of weeks.
Leant against a wall for a fortnight,
Before being knocked into table shape in a morning.
No sanding or oiling, raw.
Then left in front of a south facing window, close to a radiator.
Probably September.
It has warped and cracked but only slightly. (To my great surprise)
[emoji848][emoji106][emoji106][emoji106]
Got a bit more of the elm today, only coffee table size.
Borrowing a mill from a mate, so should get them milled on Wednesday.
