Just now, Mark Bolam said:
No, the tension stays on all the time, just swaps between straps.
Ok, but why are they joined together? Can some draw a diagram please?
Not for me, I’m as sharp as a knife and understand it completely, but there are some slow buggers reading this however, too ashamed to admit they don’t get it.
  • Haha 3
Tie one end to the thing needing winching.  The other to an immovable object.  Join them together and ratchet  away.
I get the ratcheting bit obviously, but i meant how do you physically attach the two traps to one ratchet mech?
You’ll have to forgive me as i’m not from a tree working background so your ratchet mech’s may differ, but the type i have in mind are the load restraint type ratchet mech. Like below.
I may be over thinking this?!
I'll try. Not joined together.
Put one on, strap and ratchet. Crank till the spools full. Put the other one on alongside the first, crank till the spool is full. Release the first one, pull the slack through, crank till the spool is full. Release ratchet 2, pull slack through, crank till the spool is full. Repeat till something breaks or the stuck object is unstuck.
58 minutes ago, Rich Rule said:
Call me strange, but I have a ratchet strap or two in the truck incase I need to ratchet anything down
.....*strokes chin*....." why officer ! I work in the timber industry, hence the shovel also...." ;) k
Two ratchets, two straps - they are both essentially doing exactly the same pull, but you tension/winch with one of them, then do the same with the next before releasing and shortening the first.
