Bear in mind the cells in the Aldi Workzone Li-Ion battery packs are actually made by Samsung, and are as good as any of the big name batteries, amp hour for amp hour. There are three manufacturers of top-shelf cells, Sony, Panasonic and Samsung. The Hitachi range buy from Samsung also. I think the Stihl battery stuff is Sony. While the build quality and longevity of the name brands is better, they rip you off on the batteries. Although the chargers would be better (quicker) also, if that matters to you. The charger that came with my Workzone impact driver takes 3 hours to charge a 2AH battery, the one that came with the SDS drill, takes an hour. Comparatively my Hitachi charger will charge a fully depleted 5AH battery in about half an hour.
By far the best available drill/impact driver for price is the 18 volt einhell range which are available from tool station,German made and will blow my dewalt and makita one away and only half/third the price,The drill driver pumps in 100 mm screws by the hundred on a 4 amp battery like fresh air,35 years a carpenter and  the best cordless stuff i have used.
Spec
Einhell Power X-Change 18V Li-Ion Cordless Brushless Impact DriverCatalogue p332
• 1 x 4.0Ah Li-Ion Einhell Power X-Change battery
• Brushless motor
• Driver: ¼”hex
• Charger and carry case
Maximum torque: 180Nm. No-load speed: 0-2,900rpm
Code Product For delivery Pack Size Price Quantity
£128.98
£107.48 e
Edited by topchippyles
That looks like a beast, Les!
I went for this one in the end: https://www.aldi.co.uk/workzone-brushless-drill-driver/p/082864209100600
50nm of torque, so a lot less than the one above, but a lot more than my current one. And brushless. Only a 1.5AH battery, but additional batteries can be got hold of in theory, and if this one doesn't last or doesn't do the job I need I'll upgrade.
Cheers all.
Cheers all.
Workzone FTW! Pick up the impact driver and or SDS drill on sale sometime and you get another couple of batteries.
Cheers all.
Really is a beast of a gun,drive in screws like nothing
I see you've brought one now, but in case it's relevant later or to others reading this...
I know they don't have the reputation of Makita/Dewalt/etc, but I've got a Ryobi drill which I have abused for years and it keeps going, with two batteries and charger I think it probably cost about £100.
Have also brought to go with it an impact wrench https://www.homebase.co.uk/ryobi-one-18v-3-speed-impact-wrench-r18iw3-0-tool-only-_p389743 which is absolutely brilliant around the yard, one of the best "treat" tools I've ever brought. Takes 1/2" sockets, and came with an adaptor so you can use it as an impact driver if you need to, even if slightly heavy and overpowered!
If you do go Makita, be careful as they do a homeowner type drill/driver which is branded Makita but the batteries don't interchange with any other tools in the range, a friend was fooled with this.Think it might be this one? https://www.powertoolmate.co.uk/Products/004000060012/EB%2FMAKDK18015X1?gclid=CjwKCAiAt4rfBRBKEiwAC678KVOHiimeCqN1Ztd4NxMTY3nCj49MWeY-hW_rl40BePKKcx3I1a4xCRoCMGkQAvD_BwE
  • 3 years later...
Just to update this, I've not used the driver too much, but there seems to be a bit of a wobble on the chuck. Makes it hard to drill straight, and it also seems to strip screw heads. Not sure if this is me, or using old screws I've accumulated over the years, but it will drive them (into pre drilled holes) about 2/3 of their length, then just demolishes the screw head. This is with the driver in screw mode (not drill) and on minimum torque. The driver will stop if I hold the chuck, but the screw heads don't seem to provide enough resistance to stop the driver, so it just destroys them. If i feather the trigger ever so gently, I can probably get another half turn or so, but it doesn't seem to work as I think it should. Am I missing something? I don't have any hex or socket head screws to try for a comparison...
No one mentioned WORX range, made by Positec who also do do Bauker, CAT and a couple of others, I have gradually swopped over to them on most of my power tools, strimmer and mower, been pleasantly surprised at how good they are and realistically priced if you shop around.
Is the wobble on the chuck bearing or the actual chuck?
The chuck is usually held on to the drive shaft with a screw that can be exposed by opening up the chuck fully and shining a light down the chuck hole. It can be a left hand thread...just so you know but the retaining screw may be loose other than that, if the bearings are shot, good luck with replacing them.
