Warning!!!
This is not for beginners/novices.
For professional users only.
So....
Image 1
Image 2
I'm having a long conversation with stihl about dropping a file size when the chain is about halfway done.
As the side plate angle goes to 90degrees, or you file into the tie strap if you use the same size file.
Either is not good.
My boss (a very knowledgeable and a decent bloke) totally disagrees.
Same size file all the way.
Stihl GB have been very thoughtful, this is their email.
What file size do you use?
Do you drop a file size or always use the same size?
[emoji106][emoji106][emoji106]
  • Thanks 2
I used to hear about ‘half life’ files back last century.
Not necessarily dropping a whole size, but slightly smaller.
They're definitely a thing.
Edited by Mick Dempsey
41 minutes ago, Rough Hewn said:
Warning!!!
I shouldn't reply really but if it's any help my Makita saw manual states "File the first cutter half with a 5.5 mm dia. round saw-chain file, then switch to a 4.8 mm dia file."
You can see the manual here, page 20 : http://www.makitauk.com/products/garden-machinery/chainsaws/petrol-chainsaws/ea7900p45e-chain-saw-45cm-79cc.html
Been doing that for years if I happen to have the slightly smaller file but its not critical . Certainly not " advanced " ! ?
Been doing that for years if I happen to have the slightly smaller file but its not critical . Certainly not " advanced " ! [emoji3]
Thought you used to run racing saws stubby?
Thanks Paul,
Yes this is what I'm trying to get at.
[emoji106]
Nope . Had some racing saw sprockets to play with but no competing .
