Hi guys
Im looking for a bit of advise regarding Chainsaw models: My Stihl MS 261 has packed in (crank shaft has gone).
And I'm looking for a suitable and similar spec replacement. I have been recommended 2 different brands: An ECHO CS4510- 15" and a Husqvarna 555 2018 model. I'm also looking to get a quote for a Stihl MS 261 and MS 362. I would love opinions on these models or if you would recommend any others?
I work in a forest near Brecon felling all sizes of trees for firewood and occasional pole length for Pontrilas sawmills. My budget is around £500.00
Any info would be much appreciated
Share this post
Link to post
did your 261 die because of needle bearing failure?
the echo  CS-501SX has a better spec than the echo you mentioned, they are nice saws, the antivibes arnt so good and dont last. and the chain brake mecanism is a bit weak, but the engines seem super relablie.
had a go with a husky 550 and to be honest it felt a bit nicer than the above echo but it is an auto tune saw and some people seem to have trouble with them, although we have a 560xp auto tune and that has been fine
carl
Share this post
Link to post
I,d go for a Husky 550xp great saws and i,ve had no problems with any of mine except normal wear and tear also got 560xp and thats the same
Share this post
Link to post
36 minutes ago, Ratman said:
Can you not rebuild your current 261 or has it done piston and pot too?
we got a pretty high quote for a new crank and labour .
Share this post
Link to post
Just now, Husqvarna King said:
550 or 560, if I only had one saw it would be a 560👍
Same .
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
