Re euc - yes, I took down a huge one just over two years ago.  Split it well and dried it outside on pallets under wriggly tin.  Been burning it all this winter and it is really dry (under 15% according to the moisture meter thing - I know that's only a guide but you can tell by handling as well that they're well dry).  When it was cut the sap was running freely off the saws so it was mega wet (end March I think it was) - but given the right conditions to dry it's fine (first burning was only after a year).
It lights well and burns well (spits a lot so stove best) with reasonable longevity albeit not as long as say oak or thorn.
2 minutes ago, Stubby said:
Yep . Lots of it .  Well done for getting it split as it goes off like concrete if you leave it . Stove only as it pops and bangs and spits . Good heat .
Agree with you there Stubby - I left a few knotty rounds that I couldn't be bothered with at the time and there were indeed like iron after a spell.  That said, when they'd dried up a bit after a year or so then I found they'd crack and you could smash them up with a wedge or maul.  No good for stacking then mind - I made up some cylindrical baskets out of some weldmesh fencing (about 6' tall by about 4' across) that I just chuck all the gnarly bits it and cover the top.
Just keep chucking in the top and when all is dry just snip a hatch in the bottom and pull out from there.  Think I saw the idea in that Norwegian wood book somewhere.
I was staying with some friends over the winter and had a stove in the room. Found some dry elder under a sheet of corrugated iron round the back. It burned perfectly well, with none of the clouds of toxic smoke you're supposed to get.
Agreed with big j, everyone assumes because we sell firewood we burn the best quality pieces. We don't - we have a 20inch/18kW log burner and burn everything from the short bits to stubs of branches we cut off and massive wedges from pointing gateposts, as long as it's reasonably dry it all burns fine and we rarely sweep our chimney in the 20 years we've had it.
5 hours ago, Big J said:
Also, get a massive stove if possible. Makes life much easier. You can still have little fires in a big stove, but you'll be thankful for it when you have extremely cold weather, or unsplitable lumps of wood that otherwise wouldn't fit.
Sorry J but think this is poor advice for the majority of homes. A big stove at half tick is a dirty stove due to low firebox temps. Poor for the flue and dirty emissions and with the scrutiny stoves are rightly under at the moment just seems a bad plan anyway you look at it. Most stoves I see are in homes with central heating anyway. In this situation it seems best to have a small stove that will  suffice most of the time and turn up the heating for the coldest times.
Small stove worked hard would be my advice.
I sell all sorts to my customers.  Its always dry, well seasoned timber, and they always come back.  A good mix is best as you get the best of both worlds.
1 hour ago, Big J said:
Possibly for some homes. I do so often see huge rooms with minute stoves in them (that trend has become apparent as we've looked at hundreds and hundreds of house listings around Devon over the past few months). You'll see a 20-40 square metre room, often open plan to another room or a staircase and they've put a 5kw stove in. It serves no purpose other than as a decoration.
Our home fits that description perfectly and double hight. We have an 8kw stove in it and it's way to big most of the time. I retro fitted some stove bricks to make the firebox smaller and enable clean burning with a less fuel and output. In hindsight a 5kw stove would have been spot on. Yes some are heating a large uninsulated home where a big stove may work well but this a minority  IME.
One of you on the south coast and one in Scotland, the size of stove needed will differ as much as the climate ?
