What would people recommend for sealing around the top of a chipper fuel tank?
The seal has become perished and it’s been re done previously at the service shop but as it’s an ongoing issue I will keep up with it myself.
It looks like a silicone has been used before as opposed to an actual gasket.
Wandered if there was something more resistant to fuel.
Cheers
You need to make a gasket out of nitrile rubber. Things like Petropatch work as well but not that suitable for gaskets.
Nitrile rubber is available in small sheets on ebay for a couple of quid.
24 minutes ago, White Noise said:
We,ve  made Gaskets  many a time out of old car or truck inner tubes .
Always worked  well .
Proper bodger you.
I cut an EGR blanking plate out of a Quality Street tin to see if it worked before I bought one. Should have looked first, they only cost a fiver:$
Edited by eggsarascal
2 minutes ago, eggsarascal said:
Proper bodger you.
I cut an EGR blanking plate out of a Quality Street tin to see if it worked before and bought one. Should have looked first, they only cost a fiver:$
 I am that but my  bodges work ..... Quality street   tin  ya cheap skate   ...nice one .     Ha  ha ha  you taught me well  .
1 hour ago, jjll said:
Looks like what was used to seal the tank.
It’s a Timberwolf 125 - similar tank setup as Bobs.
Will look into making a gasket to fit.
I was trawling through some gumph on diesel resistant sealants and came across this article https://acc-silicones.com/products/adhesives/diesel-resistant-rtv-silicone-sealants
If you fancy giving it a try I would be interested to know how you get on.
Not cheap https://www.silmid.com/silicones/specialty-silicones/acc-as1810-black-diesel-resistant-silicone-rtv-310ml-cartridge/
Bob
