Having a similar problem with a second hand Husky 350, it cuts out as soon as I come off the throttle, air filter is clean and have tried adjusting the L and idle screws.
The clutch does seem to be creating quite a lot of heat, though it’s on so tight I can’t get it off to check the bearing...
Expand
Don't forget its a LH thread . I find compression  is enough if you make sure the de comp is out . Use a copper or aluminum drift and twat it with a mallet in the right direction of rotation and it will spin off .
Edited by Stubby
  On 23/02/2018 at 18:08, JamesNYorkshire said:
Do you think it could be a disintegrated bearing that’s causing it to cut out?
Expand
Yes,  it could be.
But have you considered the obvious? Is the clutch spring weak,  causing the clutch weights to expand / engage the clutch drum at a to low speed ?
  On 23/02/2018 at 18:56, bmp01 said:
Yes,  it could be.
Expand
I don’t know to be honest, I’m used to stihl clutches and in general I just do the basics of maintenance, it’s one of these kind of clutches.... https://www.lsengineers.co.uk/clutch-assembly-for-husqvarna-340-350-355-chainsaws.html
and I still can’t get it off anyway...
Had a 346 with the same, clutch centre  split in half across the threads and locked clutch up stalling engine at tick over
Having finally removed the clutch and replaced it as well as the sprocket, needle bearing, air filter and fuel filter it still stalls after coming off the throttle whatever I do with the L and idle carb adjustments...
Next I’m planning to clean the carb and either clean or replace the muffler... Is there anything else I should be checking that could be the cause of this?
Thanks, James
Expand
Are all the clutch springs present?
Read more
